Tecumseh formula 11hp issue
Vega3410
I'd be open to rebuilding the carb.. I've rebuilt tons of Holley carbs..
Vega3410
Threw new carb on tonight.. started right up with no choke.. ran 2.5 hours with a decent load on it... I'm called it good.. thanks everyone
Graybob
I had the same issue. I use the same engine on a snowblower after changing the crank. It would consistently shut off and then restart without hesitation. I ruled out a lean condition as carbs will surge much longer than once or twice before they conk out if they ever do. The red light would flash on the on/off switch indicating a low oil condition. Oil lever was fine. I wasn't sure if it was a NO or an NC switch so I started it and cut the wire. the engine kept running and has never shut of again
