TB22 EC String Trimmer Piston Rings
The fact checker likes to rub it in
Don't worry I working on leaving, just got to break the habit of checking in. Already been accused of doing things that I wasn't. I done lock down my PMs, Emails, and Profile so no one can post to them. I also have quit posting most of what I could post in the line of help like where to find the rings for the TB22 EC power head.
Yeah I measured the remnants of my ring with a dial caliper.. it seemed to be exactly 3/64 on the face. What would happen if it's supposed to be 3/64 but I get the 1.2mm instead? Could that cause problems?
I'm also getting a gateway timeout at Total Seal. I'll keep trying.
Also, do I HAVE to get rings with the 2 stroke peg? Wasn't sure how much of an issue that is. Most of what I'm seeing has the same thing but flipped around a different direction... like this image below.
With the ring locating pin offset to the top, the "scalloped" end gap only fits one way. Flip ring over. Yes, you need it or ring end gap will be too big.
