High Zinc Motor Oil
THE ADVANTAGES OF USING OIL WITH HIGH ZINC CONTENT
Despite the fact that boron-based additives have come to rival some zinc motor oil additives since the limitations imposed by API on zinc and phosphorus usage, the latter are still the best when it comes to dry start protection and a host of other advantages. Zinc and phosphorus are added mainly to improve surface protection, having the important role of protecting major engine components from wear and oxidation, and removing the likelihood of solid deposits. Zinc is also known to offer extreme pressure protection, and to protect components made from ferrous materials from corrosion. As the oil thickens as a result of extreme heat, it gradually thickens, forming deposits of varnish which prevent oxidation from even occurring.
ZINC AND OLDER ENGINES
Most engine manufacturers have a minimum requirement of 1,200 parts per million of zinc when it comes to the engine oil you use. In fact, some will go so far as to void your warranty, if that amount isn’t found on oil samples taken from broken engine components. When it comes to older engines and classic cars, high zinc content is a must, and some oil manufacturers even sell special engine oil that comes with elevated ZDTP or ZDDP (Zinc Dialkyl Dithiophosphates) content. ILSAC multi-viscosity oils that are rated SM even feature special additives used for older engines that experts recommend for use in older engines.
