The Push mower
- Aug 22, 2020
- 13
- 51
Engine starts OK, but dies when the blades are engaged. Checked seat safety switch, replaced carburetor and removed fuel cap- none of these made a difference. If I turn the blades off quickly and throttle to choke the engine will continue running, so it appears the engine is not getting enough fuel. If it dies after blade engagement it will only restart with full choke and then doesn't want to run unless full choke. Let it sit for 10-15 minutes and the condition improves and I can ride around the yard with blades off. Checked service manual but it does not specify if this mower should have a fuel pump or not-this mower (Husqvarana YTH21K46; 960450026) does not have a fuel pump.
I am puzzled. Camshaft maybe? Greatly appreciate suggestions. Thanks in advance.
