The Push mower
- Aug 22, 2020
- 59
Thanks for all the input everyone.
I did put a new carb on and the new carb acts exactly like the old carb.
To test vapor lock, I setup a floor fan on high to blow heat from the exhaust away from the carb since there is no heat shield on this mower (checked diagram to verify). I let the bowl fill with fuel then started mower and quickly increased RPMs to max and engaged the blades. Mower ran for about 60 seconds it started to cut out and die. I verified fuel flow all the way through to the carb.
Ground at the fuel solenoid was cleaned and checked when I replaced the carb a few days back, which was the first part I threw at this mower. Carb came with new electrical pigtail.
This mower has had a rough life. Looks like it fell off a trailer at 30mph.
Found some more craziness with this mower-it was taped but have a replacement in the mail....
free web image hosting
No heat shield:
free web image hostingNo heat shield:
