Surch Function Sucks
SeniorCitizen
Trying to find the thread about a guy considering making his own grind stone is impossible .
I wanted to tell him to begin small and work up as this guy sharpening scissors is doing . :thumbsup:
The search function is not bad. You just have to change the settings. You have to change the setting where it says "Sort Results by" to Relevance. That improves it a lot. Then you can save the preferences so you don't have to do that every time.
Change to this: searching.jpg
Good luck! :smile:
SeniorCitizen
Using that information enter - grinder stone or grinding stone - and see what you get .
maybe it doesn't recognize your words:confused2::confused2:
Actually, I think you are right. Because for example, I did a search for "I don't like grass". I pressed enter, and all the threads relating to that came up, but it was only looking for don't & grass. As you can see, some of the words it didn't use. That can alter what it is looking for!!
Briana
I moved your thread to the Site Discussion forum. :smile:
Muhammad
Administrator
Staff member
We plan to implement google site search soon... not a fan of the built-in search vbulletin has. Google site search is pretty good. :thumbsup:
