The search function is not bad. You just have to change the settings. You have to change the setting where it says "Sort Results by" to Relevance. That improves it a lot. Then you can save the preferences so you don't have to do that every time.
Change to this:
Actually, I think you are right. Because for example, I did a search for "I don't like grass". I pressed enter, and all the threads relating to that came up, but it was only looking for don't & grass. As you can see, some of the words it didn't use. That can alter what it is looking for!!
