I have a Super Bronco and the two drive belt idler pullies have bad bearings and need to be replaced. My problem is there is no way to get access to the nut holding the second pulley in place. The designers have encapsulated the nut between the main floor and another piece of metal. The only way out is to drill a hole in the floor to get to the nut. Help appreciated. Thanks Jack
