That spec on the sump screw has been changed by Briggs to 220 in-lbs (18.3 ft-lbs) due leaking sump covers.
Technical Specifications
| Model Series | 3117 |
| Displacement | 501 |
| Oil Capacity | 48 oz (1.4 l) |
| Valve Configuration | OHV |
| Flywheel Torque | 110 lb/ft (149.0 Nm) |
| Governor Arm Torque | 40 lb/in (4.5 Nm) |
| Carb Mount | 70 lb/in (8.0 Nm) |
| Plug Gap | 0.03 in (0.75 mm) |
| Intake Valve | .003-.005 in (.08-.13 mm) |
| Exhaust Valve | .005-.007 in (.13-.18 mm) |
| Idle Speed | 1750 |
| Air Gap | .010-.014 in (.25-.36 mm) |
| Flywheel Puller Part | 19203 |
| Flywheel Holder Part | 19433 |
| Connecting Rod Torque | 150 lb/in (17.0 Nm) |
| Sump Torque | 220 lb/in (25.0 Nm) |
| Head Torque | 250 lb/in (28.0 Nm) |
