- Feb 19, 2020
- Threads
- 114
- 12,401
That spec on the sump screw has been changed by Briggs to 220 in-lbs (18.3 ft-lbs) due leaking sump covers.
Technical Specifications
Model Series | 3117 |
Displacement | 501 |
Oil Capacity | 48 oz (1.4 l) |
Valve Configuration | OHV |
Flywheel Torque | 110 lb/ft (149.0 Nm) |
Governor Arm Torque | 40 lb/in (4.5 Nm) |
Carb Mount | 70 lb/in (8.0 Nm) |
Plug Gap | 0.03 in (0.75 mm) |
Intake Valve | .003-.005 in (.08-.13 mm) |
Exhaust Valve | .005-.007 in (.13-.18 mm) |
Idle Speed | 1750 |
Air Gap | .010-.014 in (.25-.36 mm) |
Flywheel Puller Part | 19203 |
Flywheel Holder Part | 19433 |
Connecting Rod Torque | 150 lb/in (17.0 Nm) |
Sump Torque | 220 lb/in (25.0 Nm) |
Head Torque | 250 lb/in (28.0 Nm) |
