Yes I have jumped the solenoid, two large posts and got nothing. There is no power cgoing to the side of the solenoid that is wired to the starter. Yesterday I replaced the solenoid with a new one and got nothing when I tried to start the mower, then I replaced the key switch still nothing. I then jumped the seat and brake safety switches and again no power to the starter. I checked every wire for a fusible link or a fuse and have found none at all.
I am going to test to see if the key switch is getting power today, hopefully it is as it was working (cutting grass) about a week ago. If I find the key to have power CAN I unhook and jump the two wires going to the PTO Clutch and try to start the mower? Or will this damage the pto clutch.
