STIHL not standing by their product
OldMasterTech
I have a 2.5 year old STIHL - used 15 times - never dropped it. I am facing a $275.00 repair on an MS-211 that I bought for $250. I called STIHL and asked how an engine housing can crack when the plastic body surrounding the entire chainsaw was completely fine / not broken. I asked if they would stand by their product. They said "something cracked the engine housing." I said, that I'm telling as many people as I can about my experience and Kelly at STIHL tech services hung up on me. That is all FACT. I'm not a happy customer of STIHL. I will never buy their products again and I'm telling as many people as I can about this.
I agree with most of the responders - you are on your own for this one. As the (former) owner of two Husky dealerships I would love to get a dig at Stihl but unfortunately for you, I see them completely correct on this claim. Too much time has passed and too many potential variables are involved. Sorry.
slimbo
i saw this guy is at a tractor forum CRYING about his saw there:confused2::thumbdown::laughing:
Ric
Yeah I found him on several lawn forums crying about the same thing, He should realize the only thing he is doing is making himself out to be an idiot because there is basis for his accusations.
He's also not tell everyone that he has never even run the original tank of fuel through the unit in two and a half years. But, he still calls himself a respondsibile user. Notice that he has never told us who found the "crack" and if it was the shop, what was it in for? You know me, troublemaker, would someone tell me which forums you've seen him on, I'd like to follow him. Yes, I know he'll see this post, maybe get an answer.
Mad Mackie
Some folks go thru life just waiting for the next reason to complain about something as they thrive on this sort of thing!
The last time that I checked, $250 was not an expensive saw in any brand. This man needs to "get a life" as the expression goes!!!
Every owners manual that I have read addresses long term storage of fuel in a product.
I have an assortment of Stihl 2 and 4 stroke and Husqvarna equipment for lawn care and I turn the equipment over periodically to upgrade.
Mad Mackie in CT
chobbs1957
You know, what he is asking is not without precedent in US industry. I remember GM replacing the engines in some out of warranty Chevrolet Vegas back in the early 70's. Also, some car brands have repainted some makes whose paint jobs flaked off prematurely, though beyond warranty.
Sometimes there are class action lawsuits about a particular repeatedly defective model. I had a Dell Inspiron laptop whose power plug kept shorting out! There was a settlement in such a lawsuit. I had had the extended warranty, and twice during the warranty they sent a technician to replace the motherboard, as that was the only way to fix the thing where it would charge, but it wound tearing up again after the warranty ran out....
I am not an expert on such equipment. However, I fail to understand how it could be placed in storage on a shelf, intact, in a an environment that has some amount of protection from sun, humidity, and rain and then you pull it off and found the housing is cracked. That cracked, no matter what, had to have had some help, either routine or not-so-routine use.
If I were Stihl, I would document the complaint, the unit serial number, but not offer any replacement. If I were Stihl management and discovered complaints about other units of the same make and manufacture run were having the same trouble, I might reconsider. Who knows, they may find some type of pattern with quality control of the manufacturing materials or processed used on that model's particular run.
Fish
It took echo and Stihl a real long time to come to grips that they had bad fuel lines on their units a decade or so ago, they kept blaming "bad gas". I would call up the dist. as a tech and tell them that the fuel line had cracks before I gave it it's first startup as a dealer tech. On other forums I have requested pics, as they are worth 1000 words. He has not provided any.
He is just a "revenge " member, that joins all of the forums he can find to try to hurt Stihl, who has wronged him, in his mind at least. I am
realistic, and would gladly go to bat for his cause, but I haven't seen 1 pic yet!!!
slimbo
looks like copy n paste doesnt work
exotion
Wow this is to funny people are really quite dumb. I have a 1989 jeep blow a head gasket last year according to this guy I should have cried to the dealer and demanded that they fixed it. Jeep should build quality products and should have lifetime warranty on everything I can so to the "no I never over heated the thing."
No I replaced the gasket and dealt with the bad radiator.
This is ridiculous he used it 15 times in 2.5 years assuming he used it an hr at a time 15 hours so for 21900 hours it sat somewhere getting dusty and he thinks he should be the exception to the limited warranty why? Why is he so special more than likely it was his fault and he should just get over it
