Band-aid Kid
- Jan 16, 2013
- 2
- 49
Hello all.
I have a FS 80 Trimmer that need a new trimmer head. I had seen some old Echo heads that you inserted the ends of the string into the holes and then you turned the bottom? of the head and it drew the string in. When it was all drawn in you had a piece from 1 hole to the other that you cut that left you with 2 pieces out ready to go.
I have no clue which Echo unit it was and/or if it would even fit onto the end of the Stihl.
Does Stihl make a head like that?
Little help here, please.
Thanks.
Bobby
ps. maybe this should have been in the Echo arena.
Thanks.
Bobby
