- Nov 29, 2014
- 24,995
As in post # 9 two strokes require a lot higher compression than 4 strokes .
Having said that 2 ring pistons will work with lower compression than single ring ones will.
Most factory manuals do not publish a cylinder compression for good reasons.
1) they are very hard to measure accurately for engines under 100 cc, my gear is definately not up to it
2) they are not as important as leak down and crankcase pressure
Just about every manual has figures for cankcase vacuum & pressures and these are what IS important.
You have 200 PSI under the spark plug but it means diddly squat if all of that is air sucked in from outside & not through the carb.
With my gear 90 psi is a minimum compression
