Bansheetaz
- Dec 29, 2013
- 1
- 2
Hi folks....I have an older 011av runs great. Only issue is that if it sits for awhile the bar oil will find its way into the crankcase and I will have to remove the plug and clear the cylinder before I can start it. Is this common for this saw? What is the fix? Its not a major problem just a bit annoying at times. Thank you for any help
