Short story is, I own a 2015 GT52XLSi. The steering was real sloppy so I added a washer to the top of the steering stem and that helped. I checking out the steering bushing - it was worn and loose. That bushing was a round white plastic job but the on line diagrams shows a B2 bomber shaped thing with bolt holes in it. The closest machine to mine that had a round bushing was a GT48XLSi and that had a black bushing 195227 so I ordered one. It's sloppier than the broken one. So can I asume 195228 is the correct one before I order that one or am I going to have to drill and install the B2? The 228 supposedly has a smaller diameter hole....so the "garden tractors' have smaller steering colums than the cheaper lawn tractors? In the mean time the color doesn't mean much as I've black bushing labeled with both numbers and same with white. Does anyone make a more permanent bushing? I'm a tad confused.
