- Nov 29, 2014
- 65
- 24,995
Tom,
Download this file.
https://www.vanguardengines.com/content/dam/briggsandstratton/na/en_us/Files/FAQs/alternator_replacement.pdf
It has everything you will ever need to know about mower wiring in it.
At the end there are some generic wiring diagrams and note the connections at the starter switch.
If you get your magnafying glass out and look real close you will see either the letters MGBSAL or numbers 1 to 6 moulded into he back of the switch.
M & G you have already worked out
Bis battery and should always be 12 V (or better )
S= starter / solenoid and goes + 12V with the key in the start position.
A= Alternator and goes 12V when turned on ( supplies power to carb valve )
L = lights ( can also be A1, A 2 etc ) and this powers the lights
Download this file.
