If you add in Kohler spark advance then that now includes additional hot wires to the SAM module as well as the ignition modules themselves.
Thanks for your patience. Kohler engine is a 26hp Courage, spec #SV735-0018. It has two ignition modules on the side of the flywheel with no air gap. On the other type mag some people used a credit card to space it with. These modules have no adjustments. They sit next to the flywheel and can't be moved. I know I sound pretty ignorant on this electrical stuff but This is about the best explaining I can do. Please don't give up on me. Thanks again.
