OKThanks for your help. Jumper cables to good battery makes no difference.
I wrote that detailed reply because we need detailed results in order to make a diagnosis
We need to isolate an engine problem from a mower problem and an electrical problem from a drive problem
If you are not willing to do the tests I have asked you to be and post the results then I can not help you
