SeniorCitizen
- Aug 28, 2010
- 127
- 2,134
I have always wanted to know why they use sealed bearing in blade spindles and not a two piece roller bearing.
So here is my test.
Putting bearing and a race in a mtd housing with a ayp shaft ( yes I use mtd housing on my ayp decks because they are better )
First test was to press the race in without cracking the housing. Passed
I am still going to use the spacer that goes between the two bearings so I can still get the pulley and blade as tight as it needs to be without over tightening the bearings.
Going to put this housing on the left side and keep the right side with new sealed bearings.
I will run it like this until the bearing start going bad on one side. If the sealed bearings go out first I will install new ones and swap the housing left to right.
I will try and keep this updated
Being you are interested in testing, measure the length of the spacer and the distance between the housing bearing bosses using accurate micrometer measurements. Let us know the results.
Bosses - ( the shoulders that limit the distance the bearings can be pressed into the housing )
