DWINT----Get in line because you are going to get really mad at me. I'm not a moderator or administer on this form, just a memberwho likes to help out, but you have finally got to me. You keep posting quess on how to rebuild or repair your unit. The problem I have with you is that you don't listen to the answers you are given and assume that the poster is leading you in the wrong direction. You never try the suggestions and when no one answers you start another thread. "WHERE DO THE BLACK AND RED WIRES GO????". I've seen this to often. If you want help, then you at least have to try the suggestions. I'll probably get a nasty note for posting this, but if they don't like this pull my membership. Rivets
when someone gives you a mower you didn't take apart its not easy.i have fixed many mowers but electrical is my weak point.i gave out my model number and I still get no answers so yes I keep putting up posts.obviously ill have to go on another site.im getting answers like get a manual.thats not going to help me cause I don't have any ignition or safety switches.i just need a simple wiring to start it and charge it.
Don't hold back tell him how you feel.
(( racing is the only sport that you need two balls ))
