snapper push mower 7800948
ron815
I have a problem with the starter rope. I was about 3/4 done when the self propelled stopped working. I turned it off and checked the belts, and they seemed fine. I tried to start it back up and the rope won't pull. I checked it and the rope is fine. Any ideas? Thanks.
sgkent
if you laid it on the side, take the spark plug out, put a rag near the plug hole and try again. Then check the oil level and also if it has fuel in the oil now.
ron815
Thanks, I'll do that. I am concerned about the self propel not working. It has given me trouble before, but like I mentioned, the belts and everything else that has to do with the self propel seems good. I'm older than dirt, and I rely on the self pulling. Thanks.
Take pictures of the rear drive and post up here.
I can't see anything from my house from what you provided.
Videos are great too.
DaveTN
Hi. I just dragged in 3 push mowers yesterday. An old self-propelled Snapper (heavy)
and 2 Yard Man. Just unloaded one the lightest one today. Those old Snappers are
nearly indestructible but no demand for them it seems.
Snapper is barely still around. No advertising and nothing new in 50 years. Can't improve on the tried and true Snapper recipe.
I'm still waiting, to this day, some company, that offers a better push mower than Snapper. Some machine that really lights my fire. 🍿
ron815
Thanks for all the responses. After taking the plug out, I was able to start it and the self propel started working.
Another satisfied customer.
sgkent
as I indicated, be sure to check the oil level and for gas in the oil. If it was hydrolocked (which is sounds like it was) then the oil, or oil and gas had to come from somewhere. Make sure the oil is clean and to the full mark.
