Buying Advice Snapper 33" deck belt length? Is 74" compatible?
Chris972
Hello,
I have found a kevlar belt 1/2" x 74" long belt. I wonder if I can buy it for my E331523KVE Snapper.
Is the 0,25" difference crucial, or will it work? What do you think about kevlar belts?
Chris
Hello,
Chris
Again, WELCOME TO LMF! :smile:
I don't know if it is compatible, but as for what we think of kevlar belts, here is a thread that might help you. They have a different mower than you, but some of the posts in the thread are just about kevlar belts: http://www.lawnmowerforum.com/gener...vlar-vs-non-kevlar-belts-zero-turn-mower.html.
I hope that helps a bit!
-lmf :smile:
Carscw
Chris972 said:
Hello,
Chris
Very good belts.
Is the belt 1/4 inch bigger or smaller if smaller then will work just fine if bigger then will slip in in tall thick grass
Sent from my iPhone using LMF
Chris972
It is 0,25 bigger than recommanded size : 73,75".
Carscw
It will work but like I said being a 1/4 bigger it will not be as tight and could slip under a heavy load.
Carscw
Now you can go to sears and get a deck pulley that is just a tiny bit bigger to make up for the belt. Still cheaper than the $60 snapper belt.
And yes it will bolt right in to place
Chris972
Thanks a lot, I think I'll give it a try cause my dealer is out of stock.
Chris
Carscw
How much this belt cost
Chris972
It costs 17 € + 23 € for shipping to Martinique.:confused2:
