In the US most any automotive/truck/diesel oil will be detergent oil. If you want non-detergent oil look for oil marked as racing oil. Racers change oil so often detergent packages in the oil are useless. Many folks have wanted to use the "best" oil and figured racing oil was it only to find after 3000 miles the engine sludged up. Back in the 60's it was common to pull a valve cover and have so much sludge the rocker arms left impressions in the sludge.
