Hi, 5 year old Simplicity Regent 38". I have had very good luck so far with this mower and really like it.
One small issue now though. Not a big deal, more of an annoyance. When I initially set the throttle speed, as I mow the engine rpm slows down a little and I can see that the throttle handle has slipped down a notch or so and I have to then manually pull the throttle handle back up and reset it to keep the speed up.
I haven't dug into it yet, I have just been manually tweaking the throttle handle up periodically to keep the engine RPM up. Any trick on how I can make an adjustment to keep the throttle where I set it??
Thanks!
Thanks!
