primerbulb120
- Nov 3, 2014
- 43
- 1,315
Okay, it looks like your pinion gears and/or dowel pins are worn out. The cheapest place to buy them is Mowers4u.com. PLEASE NOTE that Mowers4u may have to backorder them, so if you want them ASAP get them on eBay. Here are the links:
LEFT SIDE pinion gear: mowers4u.com/spur-gear-p-4842.html
RIGHT SIDE pinion gear: mowers4u.com/spur-gear-p-4840.html
Dowel pin (works with both sides): mowers4u.com/dowel-pin-p-4843.html You will have to buy two of these if you want 1 for each side.
You could get just the pins and see if that fixes it, then get the gears too if it doesn't. Or just get the gears and pins for both sides and be done with it. Just keep in mind that you will have to pay $6 shipping and wait for the parts to arrive for each order.
Or if you're interested in buying used parts, I might have gears and pins that would work. You can have them for the price of shipping.
