Hello again Primerbulb120,
My brother is a mechanic and he stopped by last night and we were trying to troubleshoot everything and he suspects that the dowel pins within the pinion gear are shot and need to be replaced? What are your thoughts?
Thanks!
I agree. I originally thought that somebody had removed the dowel pins altogether, but they're obviously still there. Since the axles are turning but the wheels are not, that either means that
1. The pinion gears are not turning
2. The front wheels are the wrong size and the pinion gears are not turning them.
If the front wheels are the right size, the pinion gears are not turning. This could be due to one of two things:
1. The pinion gears have been switched around.
THEY ARE NOT INTERCHANGEABLE. They should be marked "R" and "L" for right side and left side. Make sure the old ones have been installed correctly before you replace them.
2. The pinion gears and/or dowel pins are worn out. I would suggest replacing the gears along with the pins, as they both wear equally.
Apply a liberal amount of grease to the dowel pins, the pinion gears and the ends of the transmission shaft (where the gears and pins attach.) Then re-install them, paying attention to the "R" and "L" markings. If the mower still won't propel itself, post back and I will give you links to the pinion gears and dowel pins.
