EngineMan Lawn Addict Feb 25, 2014 #11 Page 10 in the manual I posted. Attachments walbro whg carb.jpg 28.3 KB · Views: 9
F frantz65 Member Feb 25, 2014 #12 the main issue with these guides is that it doesn't list what each screw is on my carb.
R Rivets Lawn Royalty Feb 25, 2014 #13 Go to the Walbro website, type in WGH-17 and it will list the parts breakdown. From that you will be able to figure out the purpose of each screw.
F frantz65 Member Feb 25, 2014 #14 ok, got the screws figured out, guess its time to go heat up the garage,give it all a good cleaning and see what happens.
EngineMan Lawn Addict Feb 26, 2014 #15 frantz65 said: the main issue with these guides is that it doesn't list what each screw is on my carb. Click to expand... I take it you did not read page 19...!
F frantz65 Member Feb 26, 2014 #16 EngineMan said: I take it you did not read page 19...! Click to expand... my carb has a standard bolt at base of carb. nothing with a needle through it.
F frantz65 Member Feb 26, 2014 #18 valves I do need to look into, can hear a tick. just gotta find the clearences and how to get in there. been busy listing vintage bottles on ebay(at least trying to :laughing
F frantz65 Member Feb 26, 2014 #20 Fish said: Tecumseh Engine Intake and Exhaust Valve Clearances Click to expand... thanks for that link! assuming its like any other motor ive done? find TDC and set from there?
