OK! The screw ,just above the float,is the idle mixture adjustment. Turn it IN,until it LIGHTLY seats,then OUT 1&1/4 turns.
The screw nearest the air cleaner,is the high - speed mixture screw. Turn it in to lightly seat,then OUT,1&3/4 turn.
  Start the engine,and warm it up,& set it to idle position, then,SLOWLY turn the idle mixture screw in,until it stumbles,and note this position.
 Back it out,until it smooths out,then out more until it stumbles. Turn it IN,again until it smooths out,+1/2 turn.
Next, set the throttle at full,and slowly turn the high speed screw in,until it changes rpm.
 Back it out,until it just smooths out,then out some more,until it changes speed.
Turn it in,until max rpm is reached,then put the throttle on idle,and QUICKLY run it to full.
Any stumbling/black smoke turn it in 1/4 turn,until it is right.
Special note: These carbs are very touchy,and can be messed up with even the slightest dirt,water in fuel,etc.
