I've never done a forum before, but I cannot for the life of me figure this out. I have a scag Tiger Cub STC61V-23BV that has the 23hp Briggs vanguard. It started to completely drain a battery as I cut and leave me stranded. First thought, put a new battery. After an hour or 2 of mowing, the battery was dead. Second thought, voltage regulator. Nope, still drained the battery. Checked stator output and it was fine. Then I started getting alot of chatter from the solenoid so I replaced it. Still drained the battery. I finally noticed that the female connector on the wiring harness that goes to the seat switch was missing and all 3 wires were wire nutted together. I'm assuming this is the issue, but I cannot find that female end without buying a whole harness. If anyone else has any other suggestions or input on what might be the issue or where to get a connector I would sure appreciate it.
