forcefed4door
- Apr 20, 2020
- 1
- 3
Anyone have any experience electrically with such a beast? There is 0 repair/technical service info on these mowers. Seems a lot like a golf cart chassis and has some similar parts. I have spent a few hours trouble shooting. I have unplugged almost every accessible plug to check connections. I have voltage checked in various sections as well. If I move the rocker to forward or reverse It won't move. Blades can engage though! The 48v selanoid is fine. If I turn the key on and off enough times it will suddenly work fine like nothing is wrong. But if I turn key off and on during use it will not move once again... Turning it on/off powers the selanoid each time with a common click sound. I'm really at a loss... Jumped out all possible circuits that could cause this as well such as parking brake and seat switch. Any ideas? I'm really guessing it could be the pedal sensor or the main drive control unit. This mower is only 2 years old
