ok i got the Serial Model # M0RX75X480576 but i can find a wire diagram. the one i have say'sthat is why you need to print copies of the wiring diagram, after determining it is for your model and serial, and follow ALL the wires in that area to see if anything else has been changed. Most likely yes but I would not make that assumption without following the other wires in those two areas to be sure none are altered.
RX SN 498,493-
SX SN 481,333-
What am i missing? would like to get this running so i can mow up at my camp instead of using a push mower
