runs a second
hitch45
reynoldston do you know how to get the needle out? also what looks like a fuel shut off screws into bottom of float bowl, w/black ground an a white wire mower is model 1642h 16 hydro 10 to 12 yrs old. have done valves an such, gets gas to float bowl, cranks, won't hit.
hitch45
1642 sabre carberator fuel adjustment does any one know?thanks:confused2:
Fish
find your engine's model numbers....at least the brand
hitch45
Engine is a Briggs & Stratton 16 HP model # is 80777 type is 0662B1 It's a older Riding mower all help appreciated....
Fish
Try that number again, correctly.
reynoldston
I think that Briggs has a non adjustable float in it. The carburetor is made in Mexico and is not repairable. Like I said earlier I couldn't find parts for the one I repaired and had to replace the carburetor. Maybe with your model number someone will come up with something different then what I just told you?? I have found the time and money you spend on trying to repair some of these foreign carburetors you are better off replacing it.
Fish
So it is a Vanguard?
Fish
Sounded like one, but I still like a model number....
hitch45
will get a magnifying glass out and see tomorrow I can't find any marking on the carb at all,will check again.. thank you
reynoldston
What you will need is the engine model number. B&S puts this number on the fan shroud. ( BUT ) You will have your best luck finding parts for this mower right from a John Deere dealer with the tractor model number not the engine number. John Deere has there own part numbers.
