GregW1966
2004 rtz 50 Mower with new blades leaving a high spot. Looked underneath, far right cutter, farthest from the discharge, the new blade seems to be angled. Not dragging on the underside of the deck. I did not notice when mounting the new blades. It was cutting badly leaving the high spot prior to changing the blades. The blades were 2 yrs old and were in bad shape. Seemed to cut better. I was out of town for 2 weeks and the lawn was tall. Got on and mowed. That out side blade was leaving a strip almost uncut about half the width of a blade. I kept going and going back over what was missed. The deck kept clogging with clippings, got so bad is stopped cutting. PTO on, no cutting blades not turning. So I stopped jacked the front end to power wash the deck. It was pretty bad. Thats when I noticed the blade at an odd angle. I needed to finish so I did blowing the clippings on to the already cut lawn rather than straight line mowing. That seemed to help the clodding. I need to fix this. So questions are. Since the balde is not bent it has to be the axle, the mounting, the spindle or the deck. Pulley seems find and belt is tracking properly. I know I need to get back under there, but has anyone else had this problem? I replaced a spidle before so I know the axle is pretty thick and the spindle and mounting are cast and the deck is sheet metal. Any guesses as to what is wrong? Also why would the blade bog down to the point that they would stop turning? The rubber guide on the discharge had been gone for years. Is that part of the clogging problem or was the lawn just to tall and juicy? Do you think the electric clutch is OK? What to check first? I dont think the blade was wobbling, seems like I would have felt the vibrations. Plus if wobbling the uncut strip would be intermittent, right? It is not and is very consistent. Thanks for all input. Greg
