Hi everyone, just replaced 23 hp briggs on my La140 with a briggs cdi 2500, now when I back up with pto engaged Rio doesn't work and tries to ground eng out, like its not working, so I bypassed button and it still grounds eng out ???Any ideas???
Reverse implement operation, let's you back up with blades engaged
Plug and play, new engine harness had a green wire the old one didn't have ,Did you have to do any modifications to plugs or wiring or was it plug n play?
Just what I was unable to find. LolDo you mean something like this?
Yes reverse works fine, replaced drive belt when I did engine replacementReverse In Operation?
