Cusser
- May 3, 2019
- 16
- 246
to use the mutlimeter, do you hook the red wire to the wire you want to test and the black wire to mower's frame or something?
Yes. If you do the other way, the reading will be in "negative volts" if you have voltage there, but it won't hurt anything. Read the instruction manual or look online, pretty much all operate the same.
