riding mower suddenly died. interlock switch?
mymowerisbroke
I was mowing and it died suddenly, it didnt even spudder first. I replaced spark plug and it didnt help, it has good spark to it. I pulled the fuel line past the fuel filter and got flow, i put gas in a glass jar and didnt see water. Engine will turn well so the battery is good and like i said, i have spark.
If i have spark, then does that mean the interlock switches at the seat and under fuel tank are good? I dont want to buy the switches if theres nothing wrong with them. Only think else I can think of is that fuel isnt getting onto the pistons for some reason. Thanks for any input.
craftsman t2600 2018 model. briggs and stratton engine
If the engine is turning and you have spark, it's not a safety switch.
Give us the model of the mower, being a craftsman they usually start with 917. sometimes others due to being made by different manufacturers. Also give us the engine model numbers.
Did the engine make any knocks or bangs? also check your oil level.
its a craftsman t2600 247255880 model, its red. oil looks good, no knocks or bangs. just went dead and won't crank back up. I also took the air filter off thinking maybe it was too dirty, but it still wouldnt crank. it didnt look dirty. im glad to told me that if i have spark, then its not a switch... anything else????
Do you have any carburetor cleaner or starting fluid?
remove the spark splug and spray about 3 short bursts into the plug hole, reinstall then try start. if it goes bang, or bang bang bang then dies, it's probably a fuel issue.
You can also use gasoline, about 1 teaspoon or a little more should do.
Now, one thing i did forget to mention is the carburetor may have a fuel shutoff solenoid (usually referred to as anti backfire valve) It shuts of fuel to the main jet using a rubber plunger on the end of a steel rod. here is a picture of what the part looks like. Whenever you turn the key ON, not start, but ON you should hear it click. some seem to be louder than others with a CLICK and others a faint click.
I tried to turn on the key to hear a click from the carb, I didnt hear anything. I wonder if there is a switch that is bad that cuts the fuel?
That's what the anti backfire valve is (technically a solenoid, which is a switch) to remove it you usually need to grind down a 1/2" wrench to fit in between the bowl and flats on the solenoid. Sometimes cleaning will help them, but alot of times it wont.
but first i would check to see if there is power on that red wire when the key is on. Set a digital meter to 20 volts DC.
:ROFLMAO::ROFLMAO::ROFLMAO:
So when did an electromagnet became a switch?
It is an air core inductor that produces a strong magnet field which a moving iron core is used to either open/close a valve, to operation a mechanical switch, or other item that can operated via the pull or push of the magnetic field. Either way a solenoid itself is NOT a switch. Put two of these inductors in very closely to each they become a transformer using either a metal or air core with an AC voltage applied. In electronics they are even use as time delay devices and filters.
to use the mutlimeter, do you hook the red wire to the wire you want to test and the black wire to mower's frame or something?
