- Nov 29, 2014
- Threads
- 64
- 24,705
The governor is what SLOWS the engine so if an engine will not run slowly then the governor has failed.Thanks for the replies. Are we all thinking the same thing? Drop the sump and see what's broke.
The failure can be as simple as the shaft coming lose or as complex as the governor requiring replacement.
