Shade Tree Mech
A Briggs Engine Model 331877-1371-B1 was running fine. It was shut down to refuel and upon start up it revved very high and lowering the the throttle produced very little change. With the throttle control in low, I can manually push the butterfly plate/linkage against the idle adjustment screw to produce the low end rpm's, but as soon as I let go it takes off to high rpm's. I do not see any parts missing in reference to the parts manual. I loosened the governor arm from the shaft and it seems to make little difference to where as the adjustment of the arm position is concerning at the rpm's. Also the governor shaft seems to move a total 30 to 45 degrees. Anything else to check before I decide it is an internal problem with the governor?
