hrdman2luv
Lifted the mower up with my motorcycle lift. The shaft that comes down from the engine is turning but no pulleys are turning. The noise did sound internal from engine. The fuel filter is empty and I did look inside when I took the top off and saw no gas entering the carb. Thanks for all the help.
That doesn't compute in my brain......... There's a keyway that fit's between the pulleys and crankshaft and a bolt that tights the pulleys to the crankshaft.
BUT.... Since the shaft it turning, that doesn't explain why your not getting fuel...
Do you have gas in it? (I know, that's a stupid question) But sometimes I overlook the stupidest things... (As in some of my posted questions)
BTW, does you engine have a fuel pump? Or is it gravity fed? (With the fuel tank being higher than the carb)
