At lest 3 or 4 times a year A blade bolt has to be cut off.
It is no big deal.
Cut an X through the head then slip a cold chisel into the V of the X and give it a good hard smack.
once the head os off they undo with your fingers, the threads are never rusted in it is always simple over tightening.
In the workshop there is a 1" drive impact wrench and even that fails to remove a bolt 3 or 4 times a year.
In use they self tighten .
for on site there is an 8' length of 2x4 hollow steel tube that gets slipped over the blade, a 1" & 3/4" drive breaker bars so they are 6' & 4' long respectively.
A jack goes under the head of the breker bar so it does not fall off & the other end gets pushed with my legs .
