Boobala
- Feb 15, 2015
- 200
- 7,000
All well & good but you can not get the spindle housing off the deck until you remove the top pulley which is rusted on
The OP can not get the pulley off which was the original problem.
If he commits to an entire new spindle assy. ....... a 4 1/2" grinder and an electric sawzall will make short change of the originals ...BUT FIRST must be sure of pulley sizing and base of spindle housing for mounting bolts I recently paid $17.00 each for a new housing WITH the bearings & inner spacer installed ... I of course used my shafts, spacer (outer), pulleys, blade adapters, washers & nuts ( those are what I call the LOW-CROWN model housings )
