Replacement hydraulic oil Exmark Pioneer Suggestions
7394
Gravely recommends 75 hours for the initial change. That’s just what I did. I used the Stens branded filters. They were the cheapest on Amazon. I used Mobil 1 15W50.
My Scag has a 5 year warranty, so I will use the OE filters etc...
bkeller500
While under warranty ALWAYS use the manufacturers recommended oils. There is not that significant savings to use a cheaper oil and if you do have to go in to a service center for warranty work they will have (1) less out for helping you with getting a repair covered under that warranty. After warranty, use the same oil. It's still cheap compared to a new Hydro or a Hydro repair. Most ZT's are above $3,500........isn't it worth $35.00 for oil for maintenance? Your peace of mind is not a bad thing either.
