- Nov 29, 2014
- 24,995
Now you are talking total trash
All mowers run between 3200 & 3700.
It is a standard speed WORLD WIDE same as full sized tractors mostly have a 1750 rpm PTO or a 3600 rpm PTO depending upon the implement .
Most singles will happily do 4500 but a lot will toss the little end around 5000 rpm, done way too many racing mower engines to fall for that red herring.
Twins will usually do closer to 5000 rpm before they toss the rod but engine balance ( or lack of it ) can have you bouncing sideways above 4000 rpm.
So now finally we get some tiny hints .
FWIW I have just swapped a SV 620 with a cracked block to a 44 Vanguard in a YTH21k97
Apart from the wiring I had to make new muffler supports when transferring the B & S muffler to the hole the Kohler muffler went into.
Now that you have finally told us what we needed to know in the first place I originally wrote a detailed response .
However when I reread it and your post I decided that as you are being a total pratt, you can work it out for yourself.
So please carry out your threat and go annoy some one else .
You can carry on as much as you like because as soon as I hit the Post button I will hit the ignore button for you because you are not worth the weight of the electrons used to respond in dirty swamp water .
