Remove and clean Nikki carburetor on 21R7070039
wnlewis
I'm trying to find a repair manual for the B&S 21R7070039 engine on my Troy Built Series 26J Mini-Rider lawn tractor.
Specifically I need to remove and clean and reinstall the Nikki carburetor.
It appears that two nuts on long bolts hold the carburetor body to the plastic intake manifold.
There is a gravity feed fuel line on the right side of the the carburetor body held in position by a spring clamp.
There is another line (a fuel return line or EGR line?) that goes into the front of the carburetor body.
There has to be a throttle line attachment and maybe a solenoid and wire connector for a solenoid at some location.
From the little I have been able to read (official service manuals - not reprints - of any kind seem hard to find on the internet), the gaskets, O-rings, etc., seem to be very finicky and non-reusable. That means that if you accidentally remove such a thing, you are obligated to buy the whole repair kit - not inexpensive.
The last time that I ran the lawn tractor it ran OK. However, even with SeaFoam gas treatment, after two years, the needles valves are probably stuck shut and gasoline carburetor cleaner does not seem to help.
That means that I probably have to get the carburetor off and at least get carburetor cleaner on the throat surfaces, or maybe soak the carburetor.
If I had an ultrasonic cleaner, I could just dunk it in the tank and let it run for several hours. But I don't. Mine broke some time ago.
So it's manual methods, and learning as much as possible before starting.
Also, is the float (assuming that there is one) hollow plastic, hard foam plastic, or metal? Some float types tend to get fuel logged and have to be/should be replaced.
I've also not dealt with a carburetor for a small engine that has - could have - a solenoid. What complications does that add?
So, back to the original, easier to take care of way to respond to this request: Where do I find a good, detailed service manual?
Thanks for any help.
Easiest way to do it is to remove the blower housing.
Take the air filter off & the housing lifts strait up leaving the air horn in place
Take a photo
You then undo the nuts that hold the air horn , pull the breather tube off the back & slide it forward
Take a photo
Now pull the plug out of the solenoid , there is no catch it just pulls strait off, but do not pull on the wires, a pair of pointy nose pliers is good for this.
Take a photo
Next is the studs that hold the carb body onto the manifold.
Take a photo
You will need a deep socket or a very short spanner for this .
Take a photo
Pull the carb back a little then rotate it and the choke rod will slip out of the slot in the control panel.
Take a photo
You then flip the carb to unhook the throttle rod
Take a photo
Finally move the crab to the right so the spring that will end up spearing your finger no matter what you do out of the throttle late on top of the carb.
The manifold can stay on the engine unless you want to replace the O ring which usually only gives trouble on very old engines .
Instructions on cleaning the carb are at out door power info
wnlewis
Take a photo
Take a photo
Take a photo
Take a photo
Take a photo
Take a photo
Take a photo
I very much liked the final part . . . so the spring that will end up spearing your finger no matter what you do . . .:LOL:
A fellow is not a mechanic unless he gets at least one skinned knuckle or bloodied finger.
I will plan to take photos and see if I can do a good writeup.
The photo is for you when you come to put it back together again.
The most common question we get is "where can I get the cheapest xyz "
The second one is "where does this bit go ?"
wnlewis
You may not get anything like that from me.
I thought about writing an illustrated instruction sheet on the procedure. I worked 14 years for AGCO doing technical writing on everything from windrowers to combines to big square balers and the electronic control systems. That's why I asked for manuals.
And if there are none, or I don't like them, I may still write and illustrate the procedure. ;)
Best regards.
Briggs shop manuals are written from the standpoint that you are a trained mechanic with the knowledge to diagnose and work on something. So from a dealer standpoint they are a reference manual not the bible of repair procedures.
To remove those long studs you will need a deep well 5/16" (8mm) socket.
wnlewis
I needed the information, and didn't want to mess things up, so this is the forum where I asked my question.
wnlewis
With regard to "where can I get the cheapest 'xyz'?" I try to buy the brand that made the machine. It usually turns out better.
