smith21687
Hi,
I have a Remington Rustler RM2560. The pull cord is extended and will not retract unless done manually. From my understanding, to replace the pull cord/pulley I need to replace the entire housing. I've removed all the Torx screws but the housing will not slide off due to the hex on the shaft. My question is how to remove this shaft.
Appreciate any feedback - thank you.
- Josh
- Josh
