Remington Rustler RM2560 Pull Cord
smith21687
Hi,
I have a Remington Rustler RM2560. The pull cord is extended and will not retract unless done manually. From my understanding, to replace the pull cord/pulley I need to replace the entire housing. I've removed all the Torx screws but the housing will not slide off due to the hex on the shaft. My question is how to remove this shaft.
Appreciate any feedback - thank you.
- Josh
Look down the end of the shaft.
You will see yet another torx screw poking it tounge out at you yelling Fooled Ya.
If not then the shaft will be threaded on so you will have to use a piston lock to prevent the piston moving while you turn the hex
Usual thing is to stuff plastic rope down the plug hole
primerbulb120
Moderator
Hi,
- Josh
You have to stop the piston from moving like Bert stated, then put a wrench on the hex portion of the shaft and unscrew it. It is a standard thread, so you'll be turning it counterclockwise to loosen.
