Dreaded
- Dec 18, 2022
- 16
Did you use a ring grove cleaning tool to clean the ring groves before installing the rings? If you did not it may be the rings to tight after sitting overnight. Carbon build up in the groove will cause the ring not to compress all the way.
The cylinder is not perfect, it will have areas the rings compress in more and decompress out as the piston moves up and down. When the engine is hot and has been run some the cylinder has oil on it's surface and so is easier to turn over. But sitting overnight the oil will drain away and leave the cylinder dryer. Usually the engine will stop at about the same location but the tightness of the rings because of carbon build up will cause more friction and stop the piston at it's tightest point.
To clean the ring groves without a ring grove tool I us an old ring. I break off a peice and use it like a scraper to scrape out all the carbon build up in the grove. This way I was taught by my father which was a master mechanic.
