unioncreek
- Sep 5, 2016
- 13
- 65
I have a JD D140 lawn tractor with a B&S 22 hp V Twin engine. I just over hauled then engine and replace the rings because of oil loss. I reinstalled the engine and cranked it over a number of time trying to start it. Wouldn't start got that figured out and started it and ran for a while at varying speeds to break it in. I tried to start it yesterday and it wouldn't turn over. Thought the battery was low on charge. Put a booster battery on and it would crank over. To the top off so I could get to the flywheel. I put a socket on it and it was hard to turn over for a couple of revolutions then got easy. Cranked it over and it started right up. Today it did the same thing. Runs good once I get it started. Any suggestions on what I should do? The first thing I thought was I got the wrong rings, but the end gap was within specs and it cranks over easy after a couple of revolutions. Is it just that tight and will loosen up over time?
Bob
Bob
