Well duh, my deck came off and into the ground too. Spring time. That's why I have suspension bolts double nutted now.
If you read my post carefully, it's 2nd Hustler I have and that's how they are made, apparently. We got what we paid for. I am all for fixing it and ridding of it and finding something more reliable. Figure, ways of Husqvarna about the only choice. What gets me is my 2005 42 inch Craftsman riding mower keeps chugging along like it is not 13 years old.
I'll follow after I check on transaxles suspension. Also, I start thinking about adding L shaped brackets to prevent belt from flopping down onto cooling fans. Possibly even re routing tensioner spring, as should you pay attention to its direction, it forces tensioner roller into the main drive pulley. I already tried forcing and locking it in more tension position, but that resulted in belt friction noise. Had to back it up some.
Hmm.. Maybe even adding a second tensioner roller on that long loose belt run....
And by the way. Replacing that belt is PAIN, as you have to remove main belt. Then try putting its tensioner back on!! I had to winch it on.
